Bentley's Integrated Structural Modeling (ISM) allows structural engineers and designers to share structural engineering project information among modeling, analysis, design, drafting, and detailing software applications using the iTwin Analytical Synchronizer.
Use this Learning Resource to learn how to push a STAAD.Pro Physical Model to the iTwin Analytical Synchronizer.
Pushing a STAAD.Pro Model to the iTwin Analytical Synchronizer On-Demand Training
Learn how to push a STAAD.Pro physical model to the iTwin Analytical Synchronizer.
Download the STAAD.Pro Physical Model that was used in this video to create the iTwin Repository.
Reviewing the Members Pushed from STAAD.Pro to the iTwin Analytical Synchronizer
All Members from the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer as Curve Member Objects. Learn how to review the curve member objects, and the properties assigned to them, in the iTwin Analytical Synchronizer.
Reviewing the Surfaces Pushed from STAAD.Pro to the iTwin Analytical Synchronizer
All Surfaces from the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer as Surface Member Objects. Learn how to review the surface member objects, and the properties assigned to them, in the iTwin Analytical Synchronizer.
Reviewing the Loads Pushed from STAAD.Pro to the iTwin Analytical Synchronizer
All Primary Load Cases from the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer as Load Case Objects. Learn how to review the primary load case objects, and the load items assigned to them, in the iTwin Analytical Synchronizer.
Additional Resources for Pushing a STAAD.Pro Model to the iTwin Analytical Synchronizer
Want to learn more? See the additional resources for pushing STAAD.Pro model data to the iTwin Analytical Synchronizer.
Need help? Connect with us using the following platforms:
Bentley Communities Forum |
Bentley Technical Support |
Bentley LEARN Server |
Bentley Events |
BentleyStructural YouTube |
