Mesh Gluing in Thermo-Mechanical Solutions
In other ADINA technical briefs, we present mesh gluing applications for mechanical problems without thermal effects (see Gluing Regions with Dissimilar Meshes, Gluing in Cyclic Symmetry, Two Interesting Examples of Mesh Gluing).
In many practical applications it is desirable to use the same finite element model for mechanical and thermal or thermo-mechanical-coupled solutions. The model might have in different regions fine meshes and coarse meshes of totally different element types connected to each other, e.g., 10-node tets to 27-node bricks. Therefore, we extended the mesh gluing capability to include temperature degrees of freedom. This option can be used with 2-D and 3-D solids for:
To illustrate how gluing for thermo-mechanical problems works, we consider a simple 2-D patch test, with different meshes of 9-node 2-D plane stress elements, confined on three sides and with prescribed convection at the top and prescribed zero temperature at the bottom:
Figure 1  2D Mesh for patch-test
In the plots below, we see a linear temperature distribution and a constant heat flux with no jumps (the exact analytical solution) across the gluing line. Note that the values plotted below have not been smoothed. The effective stress is also continuous across the gluing line:
Figure 2  Temperature, Heat Flux and Effective Stress continuous distribution
Below, we show a turbine blade subjected to heat flux, temperature and centrifugal loading. Mesh gluing is used to connect the different meshes used for the root and blade. As shown in the figures below, the temperature distribution across the glued surfaces is very smooth.
Figure 3  Turbine blade subjected to heat flux, temperature and centrifugal loading
Clearly, with thermal effects now also included, the ADINA gluing capability will prove even more useful in many applications.
