Thermo-Mechanical Coupling (TMC) Analysis of a Rubber Pad
The animation shows a simplified model of a rubber pad heating up due to viscoelastic dissipation.
In the structural model, the pad is modeled using the Ogden material model with additional viscoelastic effects. In the thermal model, the pad is modeled with a constant thermal conductivity and specific heat, with convection on the free edges of the pad. Initially the pad is at 25 degrees C.
The pad is preloaded by displacing the top of the pad over a period of 2 seconds. The rate of loading is slow enough so that no viscoelastic effects are present. Then the top of the pad is sinusoidally displaced at 100 cycles/second for 5 seconds. This loading induces viscoelastic stresses, which have the following effects:
