| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | Sept. 2017 11.01.00.17 |
How to perform the "Model 5: Modeling a "dummy leg" as a pipe" as found under Modeling Approaches in AutoPIPE
Note: Suggest to insert an user defined SIF value at the interface of the vertical support and bend surface, ex. B01.
See AutoPIPE help section mentioned and video below.
