| Version(s): | 2004, XM, & V8i | ||
| Area: | Import | ||
Imported CII file with segment origin points are reset to 0,0,0.
Apparently the problem is not with AutoPIPE but with CAESAR. This is a known issue as logged under the following:
http://65.57.255.42/ubbthreads/ubbthreads.php?ubb=showflat&Number=47224&Searchpage=1&Main=10494&Words=Coord&Search=true#Post47224
According to this forum discussion, Richard Ay from Intergraph created a EXE file and sent to the user. Please contact CAESAR tech support requesting this updated file. This issue can be reproduced by creating the CII file in CAESAR and re-opening the same CII file back in CAESAR.
