| Version(s): | 2004, XM, & V8i | ||
| Area: | Import | ||
After importing a CESAR file into AutoPIPE, pressing the toolbar button "Show Pipe Properties" does not have an option to view "ALL" Pipe identifiers. Did the import corrupt the program?:
No, the program is functioning correctly. Sounds like you are using a newer version of the application. There is a new tool called "Show Options" used for viewing the different settings applied to a model ie. Pipe Properties, Press, Temp, Pipe Insulation, Hydrodynamic data, Weight, Connected segments, etc...
Use the Tool bar button "Show Pipe Properties" to see information on a specific "Pipe Identifier".
or
Use View> Show Options> drop down to see color plots with many more dynamic features to review data in a model.
Whenever upgrading to a new version of the application, please review the "readme_autopipe.htm" file located in the application folder,"C:\Bentley\AutoPIPE Selectseries", for very valuable information about the new version. In addition, see AutoPIPE Help> AutoPIPE News> settings , enable Bentley Releases & Bentley AutoPIPE options, press Refresh Button, search for the release notice of a particular version, at the bottom of the posting is a URL to a web page with more details about a release.
Example:
Bentley AutoPIPE V8i SELECTseries 4 (Commercial Release - 09.05.01.02 English) Now Available!Thu, 27 Jun 2013 17:08:00 EDTThe AutoPIPE V8i SELECTseries 4 version 9.5.1.2 is a nuclear QA and maintenance release which replaces version 9.5.0.21. There are 3 critical and 3 major errors fixed in this release plus the following minor enhancements addedImport/Export- Batch processing Option for Thermal Transient Analysis
- Batch processing Option for generating input *.mdb file
- Batch processing Option to export model as NTL
- Batch processing Option to hide the program screenGraphics- Display north arrow on graphical plotGeneral- Bundle AutoPIPE Nozzle with AutoPIPE program
- Rename "Plus" edition to "Advanced" editionAnalysis- Increase number of time history steps to 10,000To view the full defect list for AutoPIPE 9.5.1.2, go to the link below:Http://selectservices.bentley.com/en-US/Support/Downloads+And+Updates/Readme/Bentley+AutoPIPE+v09050102.htm
Also, consider taking an official AutoPIPE training class as there are many small tips an trick that are published but people never know about. Many season veterans benefit from an semi annual training class to keep skills and knowledge about the program current.
