| Version(s): | 2004, XM, & V8i | ||
| Area: | Import | ||
Caesar imported file into AutoPIPE caused "forrtrl: severe (64) - Input conversion" error
Older builds of CAESAR 5.3 have an issue with $CONTROL section - where location of a variable was incorrect. This is a known issue - that is also mentioned in release notes of CAESAR.
Following is the problem new variable that is in the middle of the CONTROL card instead of the end.
Data generated by CAESAR II / Neutral file interface Ver 5.30, 9/10 #$ CONTROL
#$ CONTROL
772 0 24 0 17 0
0
175 51 0 250 8 30
8 13 0 76 73 0
You can fix it by either changing the #$CONTROL card by moving this new variable to last row or
#$ CONTROL
772 0 24 0 17 0
175 51 0 250 8 30
8 13 0 76 73 0
0
Problem: It appears you don't have the latest CAESAR 5.3 Service Pack 2 installed
Solution: Please note that any CAESAR models exported from CAESAR 5.3 will have this problem unless Service Pack 2 or higher of CAESAR 5.3 is applied. Install latest SP2 of CAESAR 5.3 before exporting CII file.
