| Version(s): | 2004, XM, & V8i | ||
| Area: | Import | ||
The translation of Cii support to AutoPIPE produces arrangements that look messy (using a mixture of Inclines and other supports).
Caesar model:
AutoPIPE Model:
A guide in Caesar Cii model is different to a guide in AutoPIPE, Caesar only has a horizontal guide so an AutoPIPE guide has to map to 2 supports in Caesar
This creates completely wrong behavior of a 'real-world' guide as describe in Non-linear_Guide_explained.pdf
Again, this means when a Caesar file is imported into AutoPIPE each Ceasar guide is actually 2 supports in AutoPIPE.
