| Version(s): | ALL |
| Area: | Report |
| Date Logged & Current Version | June 2018 40.06.00.07 |
How to Set the Report Language for AutoPIPE Vessel?
The report language can be changed:
1. Open Vessel Properties dialog
2. Select the Report tab as per below image.
3. Change Language setting as needed.
As of Jan 2024, supported languages:
