| Product: | STAAD.pro | ||
| First Affected Version: | 21.00.00.57 | ||
| Found in Version: | 21.00.00.57 | ||
| Fixed and Released in Version: | 21.00.01.12 | ||
| Area: | ISM import | ||
| Issue #: | xxxxx |
When trying to import an ISM repository into STAAD.Pro, the Run option is grayed out
This issue has only been observed in machines which did not have any prior version of STAAD.Pro installed.
Steps to Reproduce
1) Go to File > ISM > New From Repository
2) The run option within the dialog box is grayed out
The issue is being caused by the fact that OpenSTAAD Application object is not registered by the installer. A prior version of STAAD.Pro if available, may be installed and that should take care of the problem.
The problem has been addressed in the STAAD.Pro Connect Edition Update 1 ( version 21.00.01.12 ) .
