| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Erorr |
| Date Logged & Current Version | Jan. 2024 23.00.01.367 |
The following appears when exporting the dgn:
Error
could not initialize the DgnPlatform.
OK
Why and how to avoid it?
This error may appears when the path to model is too long.
For AutoPIPE 9.4 and higher, make sure that the file path is shorter than 205 characters, if the file path is longer than 205 characters you may end up with this error.
Workaround:
In case you are working on the server location, then move the file to the local hard drive, work on the model and when finished move the final model back to the network server.
