Mesh Adaptation-Repair
In computations of fluid flow with structural interactions (FSI) or fluid flow with moving boundaries, it is necessary to update the mesh topology when the mesh is no longer valid due to node movement. This is accomplished in ADINA using a mesh adaptation-repair procedure based on the Delaunay meshing methodology. This procedure performs the following tasks:
This feature is available for both 2D and 3D analyses.
Remarks
Image Gallery
The following images are examples of the application of the mesh adaptation-repair procedure in the ADINA-F program.
Figure 1  Braking system (2D)
Figure 2  Ball moving in restricted conduit (3D)
See also the following meshing methods in ADINA:
Mapped Meshing
Anisotropic Meshing
Curvature-based Meshing
Quadrilateral Surface Meshing
Tetrahedral Meshing
Triangular Surface Meshing
Automatic Grading
