Quadrilateral Surface Meshing
Surfaces can be meshed with quadrilaterals in ADINA using a "combine/refine" methodology.
Remarks
Image Gallery
The following images show examples of quadrilateral meshing on surfaces.
Figure 1  Wheel rim
Figure 2  Mechanical part (revolved surface)
See also the following meshing methods in ADINA:
Mapped Meshing
Anisotropic Meshing
Curvature-based Meshing
Mesh Adaptation-Repair
Tetrahedral Meshing
Triangular Surface Meshing
Automatic Grading
