Triangular Surface Meshing
Surfaces can be triangulated in ADINA using either an advancing front or a Delaunay surface mesher.
Advancing Front
Delaunay
Remarks
Image Gallery
Figure 1  Mechanical part (advancing front)
Figure 2  Mechanical part (Delaunay)
Figure 3  Turbine impeller (advancing front)
Figure 4  Turbine impeller (Delaunay)
See also the following meshing methods in ADINA:
Mapped Meshing
Anisotropic Meshing
Curvature-based Meshing
Mesh Adaptation-Repair
Quadrilateral Surface Meshing
Tetrahedral Meshing
Automatic Grading
