| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | Feb 2024 23.00.01.367 |
Are the excel reports Forces and Moment results in Global or Local Coordinates?
The determination of which coordinates are being utilized can be tested within a short span of time. Nevertheless, to provide a direct answer to this inquiry, it is contingent upon the current state of the Results Model Option> Force (Global/Local) setting.
If this setting is G, than the excel Forces and moment results will bs using Global coordinates.
If the setting is L, than the excel Forces and moment results will bs using Local coordinates.
If you have a suggestion of making this better, please use these instructions here to navigate to the IDEAs page and add your innovative IDEA or vote for existing IDEA.
