.OPIM Stress Isometric Troubleshooting Guide using AutoPIPE V8i 09.06.01.xx and higher
The following issues are related to using OPIM (Open Plant Isometric Manager) from with AutoPIPE V8i 09.06.xx.xx and higher:
Item #0: Introduction to Stress ISOmetric to OpenPlant Isometrics Manager (OPIM)
a. OPIM Drawing
b. L00 out Map File in AutoPIPE
c. Quick Reference for OPIM Productivity Tools from AutoPIPE
d. Settings/Attributes in OPIM application
e. AutoPIPE Stress Isometrics Export Limitations from OPIM
Item #1: Table Issues
Item #2: Customization
Item #3: Troubleshooting: Dimension Issues
Item #4:  Troubleshooting: Drawn Components
Item #5: Reasons why stress Isometric was blank or not created
Item #6: Install OPIM without internet access
Item #7: Break Points not saved in model
Item #8: Associate a program to open DGN or DWG file
Item #9: Modify drawing border for use in AutoPIPE 9.6 and Higher
Item #10: Stress Isometric settings
Item #11: How to fix when some pipe element is extracted in the summary sheet in Rev -section in Stress Isometric?
Item #12: How to convert DGN to DWG by Batch Converter?
Item #13: In Chinese Built: Chinese Characters Not Displaying Correctly in AutoPIPE Isometric Reports
Stress Isometrics - AutoPIPE
