ADINA Modeler with Open Cascade
The Open Cascade development platform is freely available in open source and provides many important features. With ADINA-M based on Open Cascade, ADINA users are able to take advantage of CAD programs such as FreeCAD, CAD Exchanger and Datakit to create parts that can be directly imported into ADINA-M.
ADINA-M based on Open Cascade uses the same commands as ADINA-M based on Parasolid. Hence, those who are already familiar with ADINA-M can also use ADINA-M based on Open Cascade with minimal effort.
The capabilities of ADINA-M based on Open Cascade include:
Below, we show solid meshes created by the ADINA User Interface (AUI) of two parts imported into ADINA-M based on Open Cascade.
Figure 1  Cylinder head
Figure 2  Clutch housing
With the addition of the new capabilities in ADINA-M, based on Open Cascade, and other enhancements, the AUI is significantly strengthened to support the comprehensive capabilities of ADINA for analysis of structures, heat transfer, fluids, electromagnetics, fluid-structure interactions and multiphysics.
Keywords:
Open Cascade, Parasolid, solid modeling, CAD, OCC, structures, heat transfer, fluids, electromagnetics, fluid-structure interactions, multiphysics, ADINA-M
