| Version(s): | ALL |
| Area: | Calculations |
| Date Logged & Current Version | February 2024 44.00.01.014 |
Nominal yield strength (σ e) is not calculated as per EN13445-3 Clause 8.4.3 eq 8.4.3-1, Why?
For example, Lower shell, the Rp1.0% = 181 MPa, therefore the elastic limit = 181 /1.3 = 139 MPa. In the calculation we find 111.38 MPa.
We don't understand where this value comes from?
Nominal yield strength value shown in report is correct.
Refer clause 8.4.3, Note clearly says if the value of Rp 0.2 is unavailable a safe estimate is Rp 1.0/1,3.
In this case (Operating condition),
Rp 1.0 = 181 MPa
We have value Rp 1.0 (1,0 % proof strength) and not Rp 0.2 (0.2 % proof strength at temperature T), Hence as per note in clause 8.4.3,
Rp 0.2 = 181 / 1.3 = 139.23 MPa
And Now as per Equation 8.4.3-1,
σ e = Rp 0.2 / 1.25
σ e = 139.23 / 1.25 = 111.38 MPa
As you can see calculated value of nominal yield strength is matching with reported value, results are correct.
