A. As Per BS EN 13445-3
Allowable longitudinal compressive Stress (σ
c,all
) is not calculated as per EN13445-3 Clause 16.14-29
Nominal elastic limit is not calculated correctly. The nominal yield strength (σe) must be Rp1.0% / 1.3
How is the modulus of elasticity determined in APV for external pressure as per EN 13445-3?
Max allowable nozzle loads (Fmax), why Δ, K & α are zero
Tubesheet, where do the terms l1, l1' and gamma (γ) come from?
Calculate nozzle variables
Nozzle Reinforcement: APs calculation basis for EN 13445-3 set-on nozzles
Change the values for Clamp Wa and Wab
Set "d70" parameter
Maximum test pressure of all component is not considered as vessel test pressure
Calculate the values of epsilon 1+ and 1-
Design pressure considered twice for head calculation in EN 13445-3
Calculates Longitudinal stress & General primary membrane stress intensity
EN 13445-3 Clause 9.7.2.4 – Handling of Insufficient
w
for Nozzle Reinforcement in AutoPIPE Vessel
Calculations
Support Solutions & FAQ's
Bentley AutoPIPE Vessel
