| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version |
Nov. 2021 12.06.00.048 |
Stress Isometric does not create a drawing from AutoPIPE model, why?
This is very important !!!
Possible issue is related to incompatibility of software versions. Another words, one should only install versions of OPIM and AutoPIPE that have been tested with one another. Installing incompatible versions may not generate a Stress Isometric.
How to check compatibility of software installed?
1. Open AutoPIPE
2. ON the help ribbon, select Readme Command button
3. In the Read me file locate the Requirements section, and scroll down to Minimum Profile.
4. Find in the table, OPIM and note the version number.
This is the only version number of OPIM that must be used in the associated AutoPIPE version specified in the readme file.
List of compatible versions (see Release notes here for read me files online):
AutoPIPE CONNECT 23.00.01.367 - higher
OPIM 10.11.00.175
AutoPIPE CONNECT 12.08.05.027 - higher
OPIM 10.10.00.71
AutoPIPE CONNECT 23.00.00.230 -
OPIM 10.11.00.175
AutoPIPE CONNECT 12.08.01.010 to 12.08.04.009 -
OPIM 10.10.00.71
AutoPIPE CONNECT 12.07.00.346 -
OPIM 10.09.01.006
AutoPIPE CONNECT 12.06.00.048 -
OPIM 10.09.00.074
AutoPIPE CONNECT 12.05.00.16 -
OPIM 10.08.00.51
AutoPIPE CONNECT 12.04.00.13 -
OPIM v10.07.00.32
AutoPIPE CONNECT 12.03.00.17 -
OPIM v10.06.00.23
AutoPIPE CONNECT 12.02.00.14 -
OPIM v10.05.00.27
AutoPIPE CONNECT 12.01.00.09 -
OPIM 10.03.00.19
AutoPIPE CONNECT 12.00.00.16 -
OPIM 08.11.11.285
AutoPIPE CONNECT 12.00.00.14 -
OPIM 08.11.11.294
Reasons why stress Isometric was blank or does not create a drawing file?
OPIM Stress Isometric Troubleshooting Guide
