ADINA with NX
The above animation shows a roof crush analysis where the model was created in a third party pre-processor and exported to a Nastran file. The Nastran file is imported into ADINA and some small modifications are made. The analysis is then performed with ADINA and the results are translated to universal file format for post-processing in NX.
Previously, we had given an overview of how ADINA can be used with various third party pre- and post-processors (ADINA Pre- and Post-processing Options). In this News, we focus on the use of ADINA with NX Pre/Post.
Figure 1 Schematic of workflow between NX Pre/Post and ADINA
The figure above shows the schematic of the workflow between NX Pre/Post and ADINA. The steps in the procedure are:
To find out what other input and output options are available in ADINA for interfacing with various pre- and post processors, please see ADINA Pre- and Post-processing Options.
Keywords:
Finite element modeling; NX interface; Nastran file; I-deas universal file; porthole translator; pre-processing; post-processing
