Nastran Model File Export
The current capability in ADINA to import Nastran model files has enabled our users to create their models using other pre-processors that are most effective for them. The Nastran models are then used in ADINA for structural (Nastran Model File Import), CFD and FSI (Using NASTRAN Models for 3D CFD and FSI Analyses) analyses.
In ADINA, we have added the capability to also export a Nastran model file from an ADINA model. This will further open up the use of ADINA with other pre- and post-processors and with other types of analysis programs. For example, a user can
The figure above shows the example of an ADINA model post-processed in Femap using the Nastran model file and op2 file exported from ADINA.
The Nastran export model includes the following data.
This new capability will certainly provide our users greater flexibility in the use of ADINA with other systems.
