IGES Interface
Geometry from IGES files can be imported into the ADINA User Interface in 2 forms:
- As wireframe entities. The wireframe entities are then used to construct native ADINA User Interface geometry consisting of surfaces and volumes.
- As ADINA Modeler geometry. The geometry may consist of sheet bodies or solid bodies.
The following images show examples of IGES parts converted into ADINA Modeler solid bodies, and then analyzed using ADINA.
