| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version | Feb. 2021 12.05.00.16 |
Stress Isometric does not create a drawing file, why?
Answer: Network communication
Save Stress Isometric hangs if executed with model on a network path. This was only an issue with AutoPIPE v.9.3 and lower and has since then been fixed. However to rule out network location and data traffic.
Perform the following:
1. Create a new folder on the desktop that uses only typical ASCII character in the file path.
2. Copy model DAT to the folder and try to create a stress iso from this new folder location.
If this does not resolve the issue, review other reasons why a stress isometric would not be created.
Reasons why stress Isometric was blank or does not create a drawing file?
