| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version |
Feb. 2021 12.05.00.16 |
Stress Isometric does not create a drawing file, why?
Overlapping Pipe.
Scenario #1:
Perform an Consistency Check (Analysis > Model Validation > Consistency Check), and the following was reported:
W726-8: Kink in straight run of 179.9 deg at point
Take the time to fix all reported overlaps by using avoidance here before trying to create a Stress Isometric
Scenario #2:
OPIM 10.11.xx and lower does not support Jacketed piping (1532478). Suggest to export the model in different selections or split it in different small sections.
Reasons why stress Isometric was blank or does not create a drawing file?
