| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version | Feb. 2021 12.05.00.16 |
Stress Isometric does not create a drawing file, why?
Answer: Carriage return in Line Number
Perform the following:
1. Go to Segment tab on Input Grid
2. Copy entire grids to MS Excel
3. Search Line number column for "\n", note location of all occurrences.
3. Back on AutoPIPE's Segment tab of the input grids, In column Line Number, locate first occurrence found in Excel on corresponding rows in the grids.
4. Highlight all text in grid's cell, remove all text, and manually re-enter the line number.
Reasons why stress Isometric was blank or does not create a drawing file?
OPIM Stress Isometric Troubleshooting Guide
