| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Stress Iso |
| Date Logged & Current Version | Sept. 2023 23.00.00.230 |
Stress Isometric does not create a drawing from AutoPIPE model, why?
Another very important reason, application has not finished processing the model, be / have patients !!!
Depending on the size of the model, Stress isometric settings (sheet size, items per sheet, etc.), system resources, etc.. The application might be processing a particular model slowly. The best recommendation is to not touch the application; else, the dreaded (Not Responding) warning will display in the application bar. It's possible that the application is still processing the model. Once more, leave it alone and stop clicking in the application to prevent a crash.
Reasons why stress Isometric was blank or does not create a drawing file?
OPIM Stress Isometric Troubleshooting Guide
