02-03.e: Troubleshooting - Import AutoPlant / OpenPLANT PXF file into AutoPIPE
Notes:
1. Any troubleshooting should start with a complete understanding of the limitations imposed upon the imported model.
Please see the following AutoPIPE help section:
Help > Contents> Search Tab> enter "Limitations (PXF import)" (include the quotes), press List Topics button, double click on the selected topic from the list provided to see more information.
2.  See the following document: PXF - Project Exchange Format.pdf for details about the PXF file.
3. Instructions on "How to Create a Stress Analysis PXF" can be found in AutoPlant'sOpenPLANT's online help, search for " Stress Analysis PXF".
4. FYI, OpenPlant exports to PXF uses AutoPLANT's class names. In addition, at the top of the PXF file on line numbers 1028 and 1029 indicates the program and version that created the PXF file.
Item #0: *.MSG reported errors that occur when importing PXF files
Item #1: Import PXF file
Item #2: When importing PXF file, Servere (59) Fortran Error appears
Item #3: Imported piping was found to be very large compared to original pipe size
Item #4: No piping with less than 1.400 inches (35.56 mm) was imported
Item #5: AutoPLANT Duct work components crashes AutoPIPE
Item #6: Mapping AutoPLANT component to an AutoPIPE component
Item #7: Anchors added to random points in imported file
Item #8: Problems with importing Tap (branch) connections
Item #9: Link AutoPLANT model database
Item #10: Imported PXF file are blank
Item #11: Fix disconnected flanges on elbow
Item #12: Exporting Non-Standard Pipe Diameters and Thicknesses from AutoPLANT
Item #13: Export a PXF from OpenPLANT Modeler / AutoPLANT
Item #14: Specify a particular material when importing an file
Item #15: Misssing part of pipeline
Item #16: AutoPlant / OpenPLANT PXF file, supports are missing
Item #17: Base supported elbow missing from imported file
Item #18: Import model from directly from OPSE
Item #19: Global coordinates from OpenPLANT do not get carried over
Item #20: *** WARNING: Error reading line P/T data. not enough pressure/Temp data provided
Item #21:  How can I map a AutoPLANT component like a line stop support through PXF file in AutoPIPE?
Import and Export
