Modeling Approaches in AutoPIPE
Modeling Approaches
**Attention** Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytical purposes.
a. Anchor h. Bends
b. Cuts: Cold Spring    i. Flexible Joints
c. Frames j. Hangers
d. Nozzles   k. Pipes
e. Reducers   l. Rotating Equipment
f. Supports  m. Tees
g. Valves  n. Vessels
Example Systems
In order to aid users in modeling more complex piping arrangements. Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Example Systems
Choose from the following topics:
    i. PipeSOIL Interaction: Transition Example
    ii. Water Hammer (Time History) Example
    iii. Steam Relief (Time History) Example
    iv. Harmonic Analysis Example
Supplemental Documentation
In addition, with AutoPIPE V8i 09.06.xx.xx and higher, other example systems / tutorials documents can be found under Help> Contents> Contents Tab> Supplemental Documentation> select the document "Supplemental Documentation"  scroll down the document to see a list of PDF files available. Most of these documents have corresponding example AutoPIPE models under File > File > Example: see here.
Modeling In AutoPIPE:
The following list contains detailed information about specialized modeling techniques with AutoPIPE:
1. Piping:
2. Offshore and Underground Piping
3. Equipment , Supports, and Structure
4. Load:
Note: select here for additional information on different types of loads that can be applied to a model
5. Commands:
6. Miscellaneous Modeling Techniques
7. Scenarios
