h. Reducer Piping Components - Modeling Approaches, Tips, Techniques used in AutoPIPE
Attention: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytical purposes.
          Anchors        Bends
          Cuts              Flexible Joints
          Frames         Hangers
          Nozzles        Pipes
          Reducers      Rotating Equipment
          Supports       Tees
          Valves           Vessels
Reducers Questions and Answers:
Item 01: Would changing the cone angle from 0.01 to 45 deg up the expansion stress ratio from 98% to ~ 145%?
Item 02: Calculate the weight of a typical pipe fittings (i.e. Tee, elbow, reducer, etc..)?
Item 03: Correctly model a reducer mounted to the branch of a Welded Tee
Item 04: Model a reducer with a branch connection
Item 05: Apply a specific pipe property to a Reducer
Item 06: Split an existing reducer into 2 reducers joined back to back
Item 07: Modify existing piping to insert a reducer
Model Different Types of PIPING Components
