03h. "Distributed Load" - AutoPIPE load case
Comments, Questions, and Answers about distributed loads in AutoPIPE.
From AutoPIPE help:
The Distributed Load command (selected from the Insert or Modify tab) enables the user to define or modify a linearly distributed load over a specified range of points. The loading can be added to any one of the defined static load cases
Notes:
1. Distributed loads can only be modified or deleted using the input grids.  An error message will be delivered when the Modify > Other > Distributed Load or Delete > Other > Distributed Load commands are selected.
2. The copy/pasted operation for distributed loads data on a point/member is not supported.
3.  Distributed loads are calculated as linearly interpolated value at the position along the pipe.
Frequently Asked Questions:
    1. Are Distributed Loads be applied to beams
    2. Examples of a "Distributed Loads"
    3. "Distributed Load" and dynamic analysis?
Loads and Load Sets
