| Version(s): | ALL |
| Area: | Expansion Bellows |
| Date Logged & Current Version | March 2024 44.00.01.014 |
How to design an expansion bellow butt-weld to the shell?
Follow the steps given below to design the Expansion Bellow,
Step 1: Create new file and select component design, Then select Expansion Bellows.
Step 2: Enter all the required design parameters including shell internal diameter.
Step 3: Fill the data in Expansion Bellows tab
Step 4: Select appropriate material for Bellow and Collar.
Step 5: Run the calculations.
Refer below video only for your reference.
