| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Feb 2023 23.00.00.230 |
Q. I need to override stress intensification factors at all fittings, and I've done that by inserting User SIFs. When I study analysis results, bends and reducers appear as I intend, but tees do not. I'm not even sure where the tees are getting their SIF?
Answer:
Basically, there are two scenarios’:
Question. Wouldn’t changing the tee type to "welding" (sketch 2.1 of B31J) gives the same effect as the elbow then, in that it keeps my user-defined SIF? Just tried that and it doesn't.
Answer. As per the statement in B31J Gen Note d. “the components of sketches 2.1 through 2.6 the direction sustained stress or moment multiplier can be conservative taken smaller of the 3 conditions.”
So, if you change the tee type the effect will be same. Because sketches from 2.1 through 2.6 is covered under this note.
