ASME B31J Code Calculation Issues
Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about ASME B31J Piping Code Calculation Issues
  1. SIF on reducers is always 2.0
  2. Tees are not Overriding the User SIF's. Why?
  3. Values to use for reducer R2, L2, and Cone angle
  4. Crotch Radius and Crotch Thickness on a Welded / Contour tee
  5. Calculated SIF values are inconsistent with manual results
  6. How AutoPIPE Calculates B31J Tee SIFs When Geometry Values Are Set to Zero?
Piping Code Calculations
A black and white logo Description automatically generated
