| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | Aug 2019 12.01.00.10 |
For a Node Locked (Non-Select) license, does the application need to be checked out?
If you are a Non-Select User with a Node Locked license then Yes, you will need to manually check out each license for the applications you wish to license. In addition, take note of the check-out expiring date for each license. Just before the expiration date, you must check back in all the software licenses and then check out a license for each application you wish to be licensed.
This is a manual process and will need to be performed annually.
Only workaround to avoid annually checking in / out licenses would be to update to a Select subscription account. Please contact your Bentley salesperson or Bentley for details.
