topics related to Licensing AutoPIPE with a node locked license
1. Activating as a NON-SELECT or Node Locked user
Bentley On Site Admin will need to log into Connection Center Portal to register a first time computer or follow instruction to unlock and reregister a different computer - click here
Activating as a non-Select User via SES - click here
2. Move Node lock license from one computer to the next - click here (instructions near bottom of page)
3. Maximum duration for a node locked license
4. Does the application need to be checked out? -
