NOTE: It is strongly recommended that users update to the most recent version of ISM, available HERE.
| Structural Synchronizer CONNECT Edition and the updated Structural Navigator mobile app were released in October 2015. A subsequent update to the CONNECT Edition was released April 2016. Bentley CONNECT / Cloud Services is now Live … To learn how CONNECT will benefit you and your projects … click here |
Sort or filter the Objects Grid or the Properties Grid. Group objects by Type or Label. Search object properties for any string.
Compressed property groups for faster browsing.
In Synchronizer Update 1, the properties grid was further enhanced to show itemized custom properties.
Support for elliptical geometry, B-Spline geometry and custom grids for greater compatibility with grids in AECOsim Building Designer.
Create both i.dgn and next generation i-model files for use in Bentley Navigator CONNECT edition or the updated Structural Navigator mobile app. Publish files locally or to CONNECT Portal Personal Share and include additional information in attachments such as pdf, doc, jpg, png, etc.
This common imodel format can also be used by many other Bentley applications.
IFC grids now supported.
Additional IFC profile definitions supported in import and export workflows.
The latest ISM API with backward compatibility to version 3.0.
[[Integrated Structural Modeling Home]]
