01b.Model Different Types of PIPING Components - AutoPIPE
Attention: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytical purposes.
Anchor Bends
Cuts: Cold Spring           Flexible Joints
Frames  Hangers
Nozzles   Pipes
Reducers   Rotating Equipment
Supports  Tees
Valves  Vessels
Additional modeling approaches, tips, and techniques for different types of piping components?
  1. Bends
  2. Flanges
  3. Flexible / Expansion Joints
    (Pressure Balanced, Expansion, Hinged, Gimbal, Single Bellows, Tied Bellows, Tied Universal, Ball and Socket, Slip Joints, etc..)
  4. Expansion loops
  5. Nozzle
  6. Pipe
  7. Orifice type components
  8. Reducers
  9. Tee, Cross, or Branch fittings
    (i.e. weldolet, sockolet, Y-pipe, etc..)
  10. Valves
  11. Strainer / Filter
  12. Flow Meter
  13. Threaded, Socket, welded type connections
  14. Offset Drip pipe
  15. Pipe End Cap
  16. GrayLoc Connector
  17. Mule Ear Return or Plug Headers
  18. SwageLok
  19. Victaulic / Grinnell Grooved  Couplings
  20. Viking Johnson Coupling
  21. Model PN-EN 10253-2 Type A & B Pipe Fittings
  22.
Modeling Approaches
