| Version(s): | 22.00.00.15 and higher | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Installation | ||
Description
How do I install localized version of STAAD.Pro?
Localized versions of STAAD.Pro are available from the downloads center in various languages. In order to successfully install and operate these versions the following requirements should be met
The computer should be running a licensed Windows 11, Windows10 or Windows 8.1 operating system, with 64-bit system architecture. For more specific detailed information about the requirements of the operating systems, refer to Installation Requirements section of STAAD.Pro ReadMe document, available from: https://docs.bentley.com/LiveContent/web/STAAD.Pro%20Readme-v6/en/GUID-5831209F-DA5C-460C-8599-D800FC08B120.html
The following additional requirements or pre-requisites also apply for localized editions of STAAD.Pro .
