| Version(s): | CONNECT Edition (21.03.00.XX) | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Installation | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
Problem Description:
I can only find a 3mb download for the new version if Staad Pro. We require the full package.
Explanation:
The installer has been updated to provide a more consistent experience with Bentley CONNECT Edition applications. It is bootstrapped like a web installer.
This in turn will download necessary components to be installed from Bentley server. The package installer can be used with optional command line parameters to control installation location and other operations, including creating an offline installation/deployment image.
Usage:
stpst210300XXen.exe[operation][mode][options]
Where:
/install
Installs a complete local copy of STAAD.ProCONNECT Edition using all the default options.
/repair
Repairs the installed copy of STAAD.ProCONNECT Edition to the default condition.
/uninstall
Removes the STAAD.ProCONNECT Edition installation from your computer.
/layout
Used to create a deployment image.
/help
Displays a dialog with the command-line parameters available.
/passive
Only minimum display or prompts are given during the installation process.
/quiet
Suppresses the display of all dialogs and prompts.
/norestart
Suppresses any attempts to restart.
/log logfile.txt
Logs the operations to a specific file named logfile.txt. By default a log file is created in %TEMP%.
