- AutoPIPE Preview Handler error on installation
- Closed loop detected in imported model at TEE point XXX.
- E13-16: Cannot Find the specified units file
- E13-63: Invalid code material(s) detected.
- E15-13: PXD file is needed for accessing AutoPLANT data in this model Please place PXD and PXH files in same directory as DAT file.
- E15-34: Select Material library does not match
- E17-61: Stress Iso could not be completed because there is no results
- E21-40: Executing this operation can corrupt distributed load records in AutoPIPE
- E31-37: Material type not recognized. Re-enter
- E31-63: Material type not recognized. Re-enter.. message appears when using AutoPIPE
- E36-42: Tie/Link must be connected to another point
- E36-43: Connected point cannot be the current point
- E36-70: Cost must be greater than zero
- E38-95: Cannot insert component after a tee
- E39-27: Zero length not permitted
- E40-100: ASME B31J requires angle to be greater than 5.0 deg and less than 60 deg
- E54-79: No Joint Type & User SIF at the selected location(s)
- E90-21: Analysis results do not exist
- E90-35: AutoPIPE Nozzle not installed
- E90-36: Unable to export. The current pipelink file version is not supported
- E90-43: Structural Synchronizer not installed on the system.
- E102-155: This point must be an anchor/reference point
- E102-161: This point does not have reference point defined
- E119-1: Maximum number of load combinations exeeded
- E131-30: AUTOPIPE.CLR not found
- E154-16: This value must be between 0 and 2, recommended value is 0.5
- E156-38: Value must be greater than zero
- E175-28: Error in velocity profile specification
- E221: Please contact Rebis
- E511-1: Invalid AutoPIPE data file
- E512-65: the model cannot be opened
- E512-67: The model cannot be saved as at the new directory as it cannot be copied to the new model directory
- E512-109 cannot open Projectwise model
- E512-149: Model name must not contain space character before extension
- E514-2: Unable to retrieve Time History Load and Time History files
- E516-8: Demo version limit of 20 points exceeded
- E516-11: Analysis terminated: model must have more than one point
- E516-89: Program has failed to validate your SELECT subscription
- E521-22: Base point is not on selected range
- E521-24: No range specified for copying
- E522-32: Cannot find clipboard file in current directory
- E522-33: Cannot complete the paste operation
- E523-21: No Range specified for rotation
- E527-25: Point not found in selected range
- E652-100 Unable to create report, too many modes..
- E723-23: System is not complete for analysis purposes
- E726-15: System has undefined bend at following point(s)
- E726-104: Zero length not allowed at beam XX
- E732-1: Angle is 0 deg. at bend xxx
- E732-2: Angle is 180 deg. at bend xxx
- E732-3: Not enough clearance to fit bend xxx
- E737-26: Valve components are not permitted in HDPE pipe system as per CC N-755-1
- E751-1 Tee type gt 8 or lt 1. SIF not calculated
- E753-18 Cannot be reducer face
- E753-21 Error creating a closed loop, cannot specify existing point name on the same segment.
- E774-44: Equation requires more combinations to be complete
- E801-1: FATAL ERROR: Unstable System
- E801-3: No static load cases specified
- E801-4: Zero length element
- E801-5: Zero Element Stiffness in AutoPIPE
- E801-6: Zero flexible length beam
- E801-11: Fatal Error: no mass in the system
- E801-12: Cannot find next frequency
- E801-24: Number of MSRS groups is inconsistent with SAM case - Error Message in AutoPIPE
- E801-62: Unable to process any time history function
- E801-64: Undefined point name in time history load data
- E801-75: Cannot allocate memory for analysis, unload some applications.
- E801-77: Multiple use of same THP file name at a point. May copy and rename
- E801-135: Number of analysis nodes exceeds maximum limit of 10000 nodes
- E829-1: Incorrect model size in file Static analysis results will be ignored.
- E951-1: No default available. Re-enter
- E951-3: Expecting real input. Re-enter
Answer: insert a valid value into the current field before selecting a different cell / OK button.
Example: Spaces at the end of "Line class", in PIPE ID properties.
- E951-31: Cannot find or read autoplan.cnf file. Please reinstall the program.
- E962-1: File read error, please contact BENTLEY
- E962-2: File write error, check disk space
- E963-8: Non-ascii characters or "?" are not permitted in name
- E963-21: Number of characters in name cannot exceed 48
- E2021-73: Only caesar v12 or earlier versions are supported
- E2143-12:Piping code specified requires AutoPIPE Nuclear.
- E2164-15: Qualified stress for all bend and tee components should be greater than zero
- E2164-112:The value of "Modulus" must be greater than zero for following beam section material(s)
- E2261-106:B31 App J: Flexibility and SIF calculations are limited to non-soil tee points
- E2261-115: Tee Header and Branch piping cannot be on the same segment. Consider using a three-segmented tee
- Error 1316 - A network error occurred while attempting to read from the file
- Error: could not initialize the DgnPlatform.
- Error during Push operation: Cannot Create file
- Error: Input string was not in correct format.
- LoadLibrary failed with error 87
- LoadLibrary failed with error 1114: A dynamic link library (DLL) initialization routine failed
- Model was first created in:
- No load case is selected to print time history results
- No Piping with OD >= 1.400 inches is found in PXF file
- Program failed to generate C2 file
- Report not compatible with the currently opened Database
- Results database file not found
- Root Element Is Missing
- The model you are about to open as last modified in a newer version...
- Time history analysis file (*.TIM) does not exist.
Also See:
Warnings, Errors, Crashed, Confirm Messages
