4. Validation Documents
Product(s):STAAD Advanced Concrete Design
Version(s):
Environment:
Area:Concrete Design
Subarea:
Original Author: Bentley Technical Support Group
The validation documents / examples within this section are used to validate the accuracy of the design performed of Columns, Beams, Shear-walls, Isolated Foundations, Pile-caps.
Below is short description of the design philosophy considered in RCDC:
RCDC is a RCC design software that supports designing of various elements of a RC structure like:
  1. Column and Shear Wall Design
  2. Beam Design
  3. Isolated Footings (Pad, Sloped and Step) Design
  4. Pile Cap with Pile arrangements of 1 pile to 6 piles can be Designed.
  5. Slab (Regular conventional slabs) Design.
  6. Water Tank Structure Design
Short description on what is covered in the design part of each element and the validation along with code reference is provided in the validation documents available as per below list.
The validation documents are available for below mentioned design codes;
  1. American Concrete Design Code ACI 318-2014  (FPS Units)
  2. American Concrete Design Code ACI 318M-2014  (Metric Units)
  3. American Concrete Design Code ACI 318-2019  (FPS Units)
  4. American Concrete Design Code ACI 318M-2019  (Metric Units)
  5. Australian Concrete Design Code AS 3600 - 2018
  6. Euro Code - BS EN 1992 - 1 - 1 - 2004
  7. Indian Code - IS 456 + IS 13920 - 2016
