Designing Steel Buildings in RAM Structural System
RAM Structural System is composed of a number of special purpose modules. This Learning Resource will utilize the following modules to complete the workflow for the design of a steel building:
Designing Gravity Steel Members
Learn how to design gravity steel members in RAM Structural System (RAM Steel Beam and RAM Steel Column).
Performing a Lateral Analysis
Learn how to perform the lateral analysis for steel buildings in RAM Structural System (RAM Frame - Analysis).
Designing Lateral Steel Members
Learn how to design lateral steel members in RAM Structural System (RAM Frame - Steel).
Incorporating the Direct Analysis Method
Learn how to incorporate the Direct Analysis Method of the AISC 360 Specification into RAM Structural System (RAM Frame).
For additional information on the Direct Analysis Method, see the RAM Structural System Knowledge Base Article KB0112454.
Additional Resources
Want to learn more? See the additional resources for RAM Structural System.
 Knowledge Base Articles RAM|STAAD Forum RAM Ideas Portal RAM Structural System
Product Page
 RAM Structural System Training RAM Structural System
Technical Discussions
Tips and Tricks
 RAM Coffee Corners
(NAOU)
STAAD/RAM Coffee Corners
(EMEA)
STAAD Coffee Corners
(NAOU)
(SEAPAC)
Need help? Connect with us using the Bentley Support Portal.
