Accessing nPulse
To access nPulse, you can use either the web-based application through a browser or the native mobile application available for both Android and iOS devices. Here are the prerequisites and steps for accessing nPulse,
Prerequisites for Accessing nPulse:
  1. Ensure you are registered on the Bentley IMS Portal and have an account on Bentley Connect (https://connect.bentley.com )
  2. Ensure you have been added to an associated project in connect.bentley.com and are also added to the project in nPulse.
Note: Failure to meet these prerequisites may hinder your access to nPulse. If you encounter any issues while accessing nPulse, contact your organization's administrator or project administrator for assistance.
Accessing nPulse through Web Application:
To access nPulse through a web browser, it's recommended to use Google Chrome or Microsoft Edge for the optimal performance.
  1. Launch your preferred web browser on your computer.
  2. Type in the nPulse URL provided by the Bentley team into the address bar of your web browser. This URL should direct you to the nPulse login page.
  3. On the nPulse login page, enter your Bentley account credentials (email ID and password) in the designated fields. After entering your credentials, click the "Sign In" button to proceed.
  4. Once logged in, you'll be directed to the nPulse main page. Here, you can select the project you want to work on from the available options. After selecting the project, you can start working with the different nPulse modules and features.
Accessing nPulse through Mobile Application
You can also access nPulse using the mobile application on your phones or tablets. To access nPulse via the mobile application, follow these steps:
  1. Install thenPulse Application: Go to your device's app store (the App Store for iOS users, or the Play Store for Android users) and search for "nPulse." Download and install the application on your device.
  2. Once the installation is complete, open the nPulse mobile application on your device.
  3. You will be prompted to enter the nPulse URL. Type in the nPulse URL provided by the Bentley team.
  4. After entering the URL, log in using your Bentley account credential
  5. Once logged in, choose the project you wish to track within the mobile app. Click the "Sync" button to ensure your mobile app is updated with the latest project information.
    Following these steps will enable you to access nPulse via the mobile application on your device.
If you encounter any issues while accessing nPulse, you can refer to the User Manual/Tutorial Video/FAQ available in this section. Alternatively, you can reach out to your organization's administrator, project administrator, or Bentley support for further assistance.
