ISM Revit Plugin
Download HereDownload the Latest Version of the ISM Revit Plugin
See the release notes located HERE for the features in this version.
What is the ISM Revit Plugin?
Integrated Structural Modeling (ISM) is an interoperability workflow allowing design change management, revision history, and visualization of shared structural information among different specialized applications on the desktop. You can enable Revit Architecture and Revit Structure models to participate in ISM workflows. This enables you to confidently share data from Revit with ISM-enabled structural design and analysis applications such as RAM Structural System, RAM Concept, STAAD.Pro, ProStructures and AECOsim Building Designer using Bentley’s Revit Plugin.
* Requires a full version of Revit. Revit LT does not support 3rd party add-ins.
Engineering Workflows using Revit and ISM
VIDEO: Designing Rebar in RAM and Documenting in Revit
www.youtube.com/watch
VIDEO: Round Trip Interop Between Revit and RAM Concept (click HERE to view full playlist)
VIDEO: Creating Spread Footing Schedules in Revit Using an ISM model
TECH TALK: Managing Revisions to Structural Engineering Models Using ISM
Related Products
ISM and Structural Synchronizer (required for ISM Revit Plugin)
RAM Concept (structural engineering of structural slabs)
RAM Structural System (structural engineering of multi-story buildings)
Structural Navigator (mobile review of ISM models)
