STAAD.Pro - iTwin Analytical Synchronizer Workflow
iTwin Services in the STAAD.Pro Physical Modeler
In the STAAD.Pro Physical Modeler, select the Model tab and click on the iTwin Services icon to Push/Pull a STAAD.Pro model to/from the iTwin Analytical Synchronizer.
