| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | April 2024 23.00.01.367 |
Eq. 11 is missing from the stress summary of ASME NC 1972 +1972 W addenda in AutoPIPE, why?
For ASME NC 1972 +1972 W addenda, stress summary does not have any configurations for equation 11. From the dialog above, press the help and review the following subsection:
"Class 2 and 3 Equations (Regular NC/ND):> A. For code years before 1992 + 1994 Addenda, the following loads cases are associated with the equations in the summary.".
Please note Equation 11 will be calculated based on the settings of equation 10.
ASME BPV-III-1-NC, AutoPIPE Nuclear Piping Code FAQ
