| Product(s): | AutoPIPE Vessel | ||
| Version(s): | 44.00.01.014 | ||
| Area: | Error | ||
The following occurs when I perform the Strength Calculations:
Error Code 795 - API 650: design temperature >930C.
How to fix it?
AutoPIPE Vessel can design tanks for maximum design temperature only up to 93 deg C.
Storage tanks with design temperature higher than 93 deg C but lesser than 260 deg C shall be designed as per API 650 Annex M.
Unfortunately, As of April 2024 Annex M is not covered in AutoPIPE Vessel.
Feature 639739 is created against this request and will be available in future release of the software.
