Q. Install multiple versions of AutoPIPE on the same computer
Product(s): AutoPIPE,
Version(s): ALL
Area: Installation
Problem:
Due to project requirements, our company must use a certain version of AutoPIPE based on project documentations requirements. Therefore, is it safe to install and use multiple version of AutoPIPE on the same computer?
Quick answer: Yes and No
Note:
    1. This article is specific for users who are required to install and use multiple versions of AutoPIPE in accordance with project specifications. For those interested in installing AutoPIPE Nozzle for compatibility with the AutoPIPE Yearly version (e.g., 2023, 2025, etc.), please refer to the knowledge base article here.
    2. Versions that uses SES licensing - 12.00 to present
    3. Versions that used Select Server licensing - 09.00 to 11.04
    4. Version to be installed to secure installation folder (C:\Program Files\) and supports user profiles to store program data.
      • AutoPIPE Yearly versions - 23.00.01 to present
    5. Version to be installed to secure installation folder (C:\Program Files (x86)\) and supports user profiles to store program data.
      • AutoPIPE CONNECT versions - 10.00 to 23.00.00
    6. AutoPIPE V8i versions - 09.01 to 09.06
    7. AutoPIPE XM versions -  08.09 to  09.00.
Scenario #1: Installing multiple versions of AutoPIPE 6.3 to 9.6,
- Use option #1 or #2 below
Scenario #2: installing multiple generation versions at the same time. Ex. generation 10 (10.0 - 10.1)  or generation 11 (11.0 - 11.04), or generation 12 (12.0 - 12.4), etc...
- use option #1 or #3 below
Scenario #3: Install all versions of AutoPIPE at the same time
- Use Option #1 or combine options #2, and #3 below
Again, if using options #2 & #3, follow the instructions for installation, lowest version first in order to the highest version, and remember only 1 version from each individual generations.
Scenario #4: Creating stress isometrics?
 - Install the OPIM version associated with the highest version of AutoPIPE installed. Do not install any other version of OPIM with AutoPIPE that was not mentioned in the release notes.
Why? Not all versions of AutoPIPE can use a single version of OPIM. Both programs are constantly being developed. Thus some combinations of the application will cause problems. Best to only install 1 version of OPIM and create all stress isometrics with that single version. Unless you are using Option #1, in which case you can install the correct version of OPIM mentioned in the release notes into each VM.
IMPORTANT:
1. Do not violate "Opening a file with AutoPIPE:" from the following WIKI here.
2. Connection Client
After installing AutoPIPE per the options below, open Connection Client and review Updates. Be sure to install the latest version of Connection client -
Option 1: Use Update feature in Connection Client
or
Option 2: Download here and install on your own.
3. Do not install an older version than the last one installed on the system as it will corrupt files in other system folders, i.e. Isogen.
Example,
after installing AutoPIPE V8i 09.04.01.05 do not install, AutoPIPE 2004 08.06.00.12. Only workaround, uninstall all AutoPIPE versions and re-install in chronological order.
Options #1:
Install a Virtual Machine (VM) on your computer. Then create a new VM and install only one version of AutoPIPE. Create additional VM's as needed to install other versions of the program.
Option #2:
Install the different versions of AutoPIPE in ORDER!!!
Example: want to install AutoPIPE 8.5, 9.2, 9.4 on the same system.
a. Install oldest one first, completely install AutoPIPE v8.5
b. The application will be installed to the default folder location: "C:\Program Files\Bentley\AutoPIPE\",
c. Open the folder location and rename the folder to something other than the default name (ex. AutoPIPE_08.05.00.12). This is an important step because, when the next version is installed, it will be installed to the default location and does not overwrite the already installed software. Renaming the folder location will break the shortcut designations on all the desktop and menu icons. Manually update these shortcuts as required. Also, recommend naming the menu group/icon names to be descriptive of version applicable to.
d. Install the next release (v9.2) progressing in order with the next highest version number again suggest to use all default settings.
e. The default location for all V8i versions is, “C:\Bentley\AutoPIPE V8i SELECTseries”, again rename the default folder name to another name (ex. AutoPIPE_09.02.03.02), fix all short cuts in the menus and desktop.
f. Install the newest version last (ex. 09.04), using the default settings.
g. After All AutoPIPE versions have been installed, install the latest version of Bentley IEG.
h. If AutoPIPE 8.6 and lower was installed, need to install Bentley Gateway and Plant security as documented
in the installation files.
Note, AutoPIPE 2023 and all yearly versions for this point forward will be installed to specified yearly folders (ex. C:\Program Files (x86)\Bentley\AutoPIPE 2023). Therefore in theory they can be installed side by side, however there are concerns about maintaining user profile and OPIM versions.
Option #3:
At this time, user can only install one version from a given generation.
Examples
1. Install both 12.04 and 12.02 at the same time.
Answer:
Technically these versions of the program will be installed to different Program X86 folder locations, they will still share the same profiles folder.
2. Install both 12.5 and v24.0 at the same time.
Answer:
The answer is still the same as above, technically the applications will be installed to separate folders on both the Program Files and Program Files X86. The issue remains, the profile location can only store one set of files, either the ones from v12.5 or the ones from 24.0.
Workaround:
One possibility, reset the profiles each time a different version of the application is opened. Use instructions here to reset the application's profiles back to default settings.
Example. Open AutoPIPE 24, reset the profiles, each time afterwards while using AutoPIPE v24 there is no need to reset the profiles. However the next time that AutoPIPE 12.5 is opened the user will need to reset the profiles. And again, the next time that AutoPIPE 24 is opened, say it with me, " the user will need to reset the profiles".
Download, Install, Release Note information
