Russian SP 16.13330 axial check verification
 Product(s):STAAD.Pro
 Version(s):All
 Environment: N/A
 Area: Steel Design
 Subarea: Verification
 Original Author:Anisurya Ghosh
BSW-Structural Design, Bentley Kolkata
The following is a validation problem for a detailed calculation of the axial check for the Russian SP 16 I section design.
A 7.5 m long column formed from a HD320X127 I section (Steel grade: S235), is checked for an applied concentrated load of 3500 KN at the tip.
STAAD PLANE
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 0; 2 0 7.5 0;
MEMBER INCIDENCES
1 1 2;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY EUROPEAN
1 TABLE ST HD320X127
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 PINNED
2 FIXED BUT FY MZ
LOAD 1 LOADTYPE None TITLE LOAD CASE 1
JOINT LOAD
2 FY -3500
PERFORM ANALYSIS
PARAMETER 1
CODE RUSSIAN
KY 0.75 ALL
KZ 0.75 ALL
SGR 1 ALL
TRACK 2 ALL
CHECK CODE ALL
FINISH
Section Properties:
HD320X127
D= 320 mm, B= 300 mm, Tf= 20.5 mm, Tw= 11.5 mm, Ix= 30820 cm4, Iy= 9239 cm4, Wx= 1926.5 cm3, Sx= 1070 cm3, J= 225.1 cm4, H= 2.069*10^12 mm6
rx = 13.8 cm, ry = 7.57 cm, An = 161 cm2
Material Properties:
S235
E = 205000 MPa, fy = 235 MPa, γc1 = 1, γc2 = 1
Check for Axial Force:
N/(An*Ry*γc) < = 1
So, 3500/(161*10-4*235*1000*1.0) = 0.9251 < 1 [OK]
STAAD.Pro value is 0.92 [Matching]
KY = KZ = 0.75
λx = KL/r = 7.5*0.75/0.138 = 40.76
λy = KL/r = 7.5*0.75/0.0757 = 74.3
λ̅x = λx*√(Ry/E) = 1.38
λ̅y = λy*√(Ry/E) = 2.516
 λ̅ = 2.516
N/(ф*A*Ry*γc) < = 1 [eqn. 7]
From eqn. 8, we get:
Ф = 0.5*[∂-√(∂2-39.48*λ̅2)]/(λ̅)2
From eqn. 9, ∂ = 9.87*(1-α+β*λ̅) + λ̅2
From table 7, we get α = 0.04, β = 0.09
So, ∂ = 9.87*(1-0.04+0.09*2.516) + 2.5162 = 18.040
Now, ф = 0.5*[18.04-√(18.042-39.48*2.5162)]/2.5162 = 0.7385 < 7.6/λ̅2, i.e. 1.2006 [OK]
N/(ф*A*Ry*γc) = 3500/(0.7385*0.0161*235000*1.0) = 1.2526 > 1.0
STAAD.Pro value is 1.25 [Matching]
hef = D-4*tf = 320-4*20.5 mm = 238 mm
λ̅w = (hef/tw)*√(Ry/E) = 0.693
STAAD.Pro value is 0.699 [Matching]
From table 9, < λ̅uw = 1.2+0.35*λ̅ = 2.0806 (eqn. 24)
STAAD.Pro value is 2.08 [Matching]
Hence, λ̅w < λ̅uw [OK]
bef = 0.5*(B-2*tw) = 0.5*(300-4*11.5) = 127 mm
λ̅f = (bef/tf)*√(Ry/E) = 0.209
STAAD.Pro value is 0.209 [Matching]
From table 10, < λ̅uf = 0.36+0.1*λ̅ = 0.6116 (eqn. 37)
STAAD.Pro value is 0.611 [Matching]
Hence, λ̅f < λ̅uf [OK]
ItemSTAAD.Pro ValueHand Calculated Value% Deviation
Ratio-Cl 7.1.10.920.92510.5543
Ratio-Cl 7.1.31.251.25260.2080
λ̅uw 2.082.08060.0288
λ̅uf0.6110.61160.0982
